VpCI®-395 Epoxy Primer is a fast drying, 2K water-based epoxy one coat system (primer) that can be applied DTM (Direct to Metal) and provides protection in harsh, outdoor, unsheltered applications. The complex mixture of non-toxic, organic inhibitors offers protection that competes with most paints and zinc-rich primers. Provides multi-metal protection. Excellent for immersion type conditions. Can be used as a topcoat for interior only applications (those not exposed to UV light). Can be matched to most custom colors.
Each coating job has different priorities-whether convenience, corrosion protection, outdoor durability, or chemical resistance. In the first case, single-component, one-coat, direct-to-metal (DTM) coatings systems are great for applications that need quick protection without a lot of time to wait for primers and multiple coats to dry and cure. However, when time does allow, it is best to put in a little extra effort-using 2K products, primers, and multiple coats-in order to achieve the best coating performance possible. That is where VpCI(r)-395 comes in as Cortec's first-class, 2K metal primer for corrosion protection!
VpCI(r)-395 is Cortec's most durable anticorrosion primer. It not only promotes good surface adhesion between the metal and topcoats, but it also has greater strength as a 2K (two-component) primer. The extra effort that goes into mixing two parts together at the jobsite translates into greater durability because it allows crosslinking, i.e., greater chemical bonding, between the active ingredients in the primer. VpCI(r)-395 shows excellent performance in salt spray and humidity testing. VpCI(r)-395 has the worker and environmental advantage of being water-based. Water-based coatings make cleanup easier and are often associated with lower VOCs (0.2 lbs/gal [24 g/L] in the case of VpCI(r)-395). Thus, VpCI(r)-395 reduces worker exposure to solvents both in the painting and cleanup process. VpCI(r)-395 can be used in various applications.
VpCI®-395 is a fast drying, 2K water-based epoxy one coat system (primer) that can be applied DTM (Direct to Metal) and provides protection in harsh, outdoor, unsheltered applications. The complex mixture of non-toxic, organic inhibitors offers protection that competes with most paints and zinc-rich primers. Provides multi-metal protection. Excellent for immersion type conditions. Can be used as a topcoat for interior only applications (those not exposed to UV light). Can be matched to most custom colors.
UFI:
• 44E0-907Y500F-V313 (Light Grey Part A)
• D7E0-S0XC-F00X-HEM5 (White Part A)
• J2E0-S0JJ-U00X-6RF1 (Part B)
Package:
VpCI®-395 is available in 5 gallon (19 L) kits: Part A - 4 gallons, Part B - 1 gallon.
To ensure best product performance, store in original packaging, indoors, and out of direct sunlight at 4-100 °F (4-38 °C).
Shelf life:
One year
