DC-1100SA, DC-1700SA Semiautomatic Bandsaws
DoALL has added two larger capacity dual-column, semiautomatic bandsaws to its Continental series product line. The DoALL DC-1100SA offers semiautomatic capacities on rectangles at 43.3″x43.3″ (1,100mm x 1,100mm) and the DC-1700SA (pictured) boasts a rectangle capacity of 67″x51.2″ (1,700mm x 1,300mm).
Both the DoALL DC-1100SA and DC-1700SA horizontal bandsaws are ideal if you need a high-production bandsaw but have operations that do not require indexing or automatic cutting cycles. The proven feed system from DoALL increases blade life and cutting accuracy as the operator is not manually pressuring or overloading the saw blade during the cut, according to the company.
