![](/sites/default/files/styles/product_image/public/product_images/TitanTool0816.jpg?itok=ArOS6hUB)
Titan Tool Supply Inc. announces the introduction of a line of micro diamond and borazon grinding pins designed to meet an increasing demand for extremely small, precision ID grinding. The grinding pins, starting at a 0.016” diameter, are on a carbide shank, which provides extra strength and precision. The working ends of the pins are coated with either diamond or borazon, using a 500/600 grit on the 0.016”-dia. model and 325/400 grit on the 0.020” and 0.024” diameters.
According to Titan’s president, Frank Menza, “We have been receiving more demands from our regular micro finishing tool customers, especially in the ceramics and electronics industries, for grinding pins that can be used in very small openings.” He expects to find applications in other industries such as mold, tool and die making.
- ceramics
ceramics
- finishing tool
finishing tool
Tool, belt, wheel or other cutting implement that completes the final, precision machining step/cut on a workpiece. Often takes the form of a grinding, honing, lapping or polishing tool. See roughing cutter.
- grinding
- inner diameter ( ID)
- shank
shank
