EVN Grinding Oil
EVN Grinding Oil
EVN provides additional benefits over normal grinding oils. Its combination of low viscosity (5.4 cSt) coupled with a high flash point (370 degrees F) is not possible in petroleum based products. That means that EVN improves flushing, which helps grinding performance while also providing the increased safety features.
February 10, 2021
Transor Filter USA has introduced a new line of grinding oil branded EVN. EVN's "Environmentally Friendly" designation is because, unlike most grinding oils that are petroleum based, EVN is a vegetable based oil. EVN is completely biodegradable and it is not harmful in cases of leakage or spills.
Compared to traditional grinding oils, EVN users have experienced up to 30% less evaporation along with significantly reduced misting, thus reducing maintenance making it a very cost effective investment. When EVN is used in Transor's One Micron filtration systems featuring automatic backflushing, its life expectancy is indefinite.
