Fastt-Grind Ceramic Discs
Fastt-Grind Ceramic Discs for use on High-Speed, Right-Angle Grinders
Fastt-Grind Ceramic Discs Combine the high material removal of a grinding wheel and rapid cut rate of a resin fiber disc.
  • Specially designed for use on high-speed, right-angle grinders
  • No back-up pad needed
  • Performance: Premium Ceramic Grain - provides a cooler cut for a longer lasting disc; 50 Grit – less emphasis on aggression with refined surface finish; 36 Grit – best combination of stock
  • removal and surface finish
  • Applications: Works well on stainless steel & carbon steel, weld bead removal, chamfering and beveling, flame-cut steel removal, edge grinding and deburring
  • Cuts time to complete jobs by up to 50%
  • 70% lighter than traditional grinding wheels reducing vibration and operator fatigue
  • Designed for ease of use with no back-up pad required
  • Thinner than traditional grinding wheel
  • chamfering
    chamfering
  • fatigue
    fatigue
  • grinding
  • grinding wheel
    grinding wheel
