Fine Filtration Systems for Tool Grinding
With rising energy costs, new laws and a new environmental conscience, the topic of energy efficiency of production machinery is increasingly being discussed and influences more and more purchasing decisions. The same holds true for filtration systems designed to clean cooling lubricants in the tool manufacturing process. Distributed by oelheld, the filtration specialist VOMAT prides itself to provide systems that filter in an energy efficient way, saving a lot of operating cost, just as its compact design does, by utilizing less expensive production floor space.
September 1, 2014
The filtration of cooling lubricants is an important part of the overall process in the grinding of carbide and HSS tools. Optimal filtered cooling lubricants protect the grinding wheel, machine components, and help to keep the quality of the finished tool at a high level.
Jens Strebelow, Production Manager at VOMAT: "In many cases, conventional filter systems require a lot of floor space and therefore waste expensive production area. This must not necessarily be the case, since VOMAT offers the FA-series, a compact, powerful and considerably smaller filtration system, which can be are tailored exactly to customer-specific requirements and can easily be integrated into the production process. For example, the company provides VOMAT filter systems with dimensions, as small as 1x1x1,6 meters ( 3.3 x 3.3 x5.3 feet), which is much smaller than comparable systems. Moreover, the compact design simplifies shipping."
But small and compact does not mean being inefficient: Vomat's unique design features guarantee reliable and cost effective operation. Full flow filtration ensures 100 percent separation of dirty and clean oil. The system permanently provides clean oil in NAS 7 Quality (3-5µm) to the grinding machine. Another advantage is the energy efficiency of VOMAT Technology: VOMAT filtration systems filter and backwash only as required. This means that the backwash modus is only activated when the filter elements are contaminated to a degree, where back flushing becomes necessary.
During the backwash cycle there is always enough clean oil available for the production process. The need-based filtering of the oil in conjunction with the need-based filter cleaning offers many advantages: The system adapts automatically to changing production volumes and adjusts itself accordingly. For example, when the grinding machines run at reduced speeds the VOMAT filtration system will only filter the required amount of oil.
If a grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" title="Powers a grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" aria-label="Glossary: grinding machine">grinding machine in the connected machine pool is stopped for change over or else, less dirty oil will reach the Vomat system. This does not only save considerable energy but also increases the life of the filter elements and the coolant itself appreciably. At the same time, less heat is transferred to the coolant, which in turn reduces energy costs for cooling the filtration medium. All this combined reduces energy consumption and leads to considerable savings.
Strebelow: "Clean coolant in the carbide and HSS tool grinding is an important factor for achieving high quality of the final product. Saving energy resources is nowadays an important design aspect for Vomat engineers. Vomat filtration systems do not need to run constantly and with maximum output. VOMAT systems reduce due to their compact design and energy-optimized operating mode, the production costs for our customers. This proofs, that the selection of the right filtration system will ultimately influence cost of production."
  • grinding machine
  • grinding wheel
