Flexcut Mill Scale Grinding Wheel
Walter Surface Technologies introduced the FLEXCUT MILL SCALE grinding wheel. The new FLEXCUT MILL SCALE has an innovative product design that improves mill scale removal and takes the hassle out of the mill scale removal process, according to the company. The FLEXCUT MILL SCALE is a premium-performance flexible grinding wheel that is specially formulated to prevent glazing or disc clogging and uniquely designed with a wider surface contact area for faster and easier mill scale removal.
"Iron oxide or mill scale removal is often a tough, time-consuming and costly undertaking. The hassles involving dust-clogged discs and frequent disc changeovers lead to lost productivity. Walter has successfully created the new FLEXCUT MILL SCALE grinding wheel to eliminate abrasive glazing or clogging, while ensuring a hassle-free mill scale removal experience. Users will benefit from significant time and costs savings by using this premium product," says Marc Brunet Gagne, Product Manager, Walter Surface Technologies.
With a unique blend of highly refined, friable abrasives paired with its open diamond cut pattern, FLEXCUT MILL SCALE is designed to grind off mill scale rapidly and will self-dress to avoid clogging.
In addition to removing mill scale, FLEXCUT MILL SCALE features a FE-Free formulation guaranteed to not contaminate aluminum and is very effective when used for rust removal on heavily rusted plates, aluminum or galvanized metal, ensuring a clean and even surface every time.
  • abrasive
    abrasive
  • grinding
  • grinding wheel
    grinding wheel
  • milling machine ( mill)
