3D Systems announced the release of GibbsCAM 2016 software for production machining. Building on the Universal Kinematic Machine (UKM) technology of the previous edition, GibbsCAM 2016 delivers a variety of improvements to increase efficiency, accelerate programming speed, and enhance visualization and accuracy for CNC machine programming. The GibbsCAM platform provides a complement to additive manufacturing processes, further empowering 3D Systems’ users to transform digital concepts into physical realities.
The enhanced kinematic framework of GibbsCAM 2016 makes it a versatile CAM platform that is effective in nearly every manufacturing environment, according to the company. Enabling solutions for complex programming challenges, such as oriented turning scenarios, GibbsCAM is compatible with a wide range of programming and machining operations, including solid modeling, high speed machining, 2- to 5-axis milling, wire EDM, multitask machining and more. Recognized for its ease of use, GibbsCAM is designed to help users eliminate scrap and reduce cycle times.
New features and functions of GibbsCAM 2016 include:
Enhanced thread milling, including support for multi-point tools, tapered threads for both single- and multi-point tools, and improved simulation.
The latest VoluMill technology, providing new toolpath strategies to optimize high speed roughing of large pockets and slots, open face milling strategies that can decrease cutting time by up to 60 percent, and Technology Expert integration for ready access to optimal speeds and feeds.
New oriented turning capabilities, giving users added control in how tools interact with parts. From using a single tool at multiple B orientations to reorienting tool groups for use on a different spindle to full support of Flash Tooling for multiple-orientation turning tools, GibbsCAM 2016 delivers increased flexibility and control to CNC programmers.
Added toolpath strategies for 5-axis milling, enabling users to define toolpath direction using the natural flow of a surface with the new Flowline option. Toolpaths can also now be extended in width as well as length. Additional enhancements include improved 5-axis drilling, multi-stepped pocket roughing and new gouge checking strategies.
“The GibbsCAM platform is a key component in today’s advanced manufacturing workflows, allowing our customers to optimize their machine processes and unlock greater productivity,” said Calvin Hur, Vice President, Co-Chief Operating Officer and Chief Revenue Officer, Software Products, 3D Systems. “By working closely with users over the past year, we’ve enhanced our understanding of the evolving needs of the factory floor, and are pleased to offer these improvements to help our customers maximize efficiency, safety and profitability.”
- flash
flash
Thin web or film of metal on a casting that occurs at die partings and around air vents and movable cores. This excess metal is due to necessary working and operating clearances in a die. Flash also is the excess material squeezed out of the cavity as a compression mold closes or as pressure is applied to the cavity.
- toolpath( cutter path)
- turning
- wire EDM
wire EDM
