Grinder and Vise Stands
Herkules Equipment Corp.'s Vise and Grinder Stands offer any workshop more flexibility on the placement of either a vise or a grinder within their facility.
Herkules Equipment Corp.'s Vise and Grinder Stands offer any workshop more flexibility on the placement of either a vise or a grinder within their facility. The Herkules Vise and Grinder Stand can swivel up to 360 dgrees and locks into position, allowing the vise or grinder to be placed in the most ideal position for the task, and then moved back out of the way when not in use. Valuable bench or counter space is saved, where vises or grinders are typically located.
The stand is available in either a floor mount or a wall mount. The wall mount allows for mounting at any desired height. The floor mount is 34" high.
The stand securely bolts to either the floor or a wall for stability, and has a 150-lb. capacity. Any size vise or grinder can be attached to the 8" x 8" x ¼" steel base plate.
