Machinable Shaft-End Adapters
A new standard line of machinable shaft-end adapters that are offered with a plain bore or keyway and a variety of options is being introduced by Stafford Manufacturing Corp.
October 15, 2019
Stafford machinable shaft-end adapters feature the Accu-Clamp design with an integral clamp on one side while leaving the other side fully custom-izable by the user. Available with or without a flange, these parts can be modified by the user or by Stafford and are offered with a plain bore or keyway for greater torsional holding power and fixed shaft phasing.
Suitable for use in conveyor systems and special machinery, Stafford machinable shaft-end adapters can be provided with options, including custom bolt-hole patterns, indexers, cam profiles and milled slots. Available in aluminum, steel and stainless steel, they come in 11 standard bore sizes from 0.5" to 2.0" ID.
