MetalMizer introduces the new MV2018 metalcutting bandsaw. Engineered to save space without compromising production, the redesigned MV2018 enhances MetalMizer's presence in the metal cutting industry, according to the company.
The MetalMizer MV2018 is designed to offer the same or greater cutting capacity of other saws in its class with over 30 percent less machine depth. By mounting the motor drive system directly on the cutting head, the MV2018 eliminates the need for a spline drive, allowing for more flexibility by occupying less floor space.
Main Features:
• Cutting capacity: 18" horizontal, 20" vertical
• 45 degree tilting saw head with 3°Forward tilt
• 0-175 pound cutting pressure
• 2 HP, 230v/460v, 3-phase drive motor
"MetalMizer has been a staple in small and midsize operations since its launch in the mid 1980s," said MetalMizer Spokesperson John Storm. "The newly engineered MV2018 is our solution to providing a high-quality, space saving metalcutting saw for the industry."
Featuring a large cutting capacity, the MetalMizer MV2018 is ideal for cutting pipes and steel profiles with awkward bends and compound angles. The MV2018, also suited to cut large diameter plastic pipes and cardboard tubes.
- bandsaw
bandsaw
Machine that utilizes an endless band, normally with serrated teeth, for cutoff or contour sawing. See saw, sawing machine.
- sawing machine ( saw)
