No. 852 High-Temperature, Walk-In Oven
No. 852 is an 850° F (454° C), high-temperature walk-in oven from Grieve, currently used for heat treating and baking varnish at the customer's facility. Workspace dimensions of this oven measure 60" W x 96" D x 72" H.
June 20, 2017
No. 852 is an 850° F (454° C), high-temperature walk-in oven from Grieve, currently used for heat treating and baking varnish at the customer's facility. Workspace dimensions of this oven measure 60" W x 96" D x 72" H. 120kW are installed in Incoloy-sheathed tubular heating elements, while a 7,800-cfm, 5-hp recirculating blower provides combination airflow to the workload.
This Grieve oven has 8" insulated walls and a 4" insulated floor. Additional features include an aluminized steel interior and exterior and safety equipment for handling flammable solvents, including explosion venting door hardware.
Controls on the No. 852 include a digital indicating temperature controller and manual reset excess temperature controller with separate contactors.
