No. 876 Gas-Heated Belt Conveyor Oven
No. 876 is a 500º F gas-heated belt conveyor oven from Grieve, currently used for drying brass and aluminum parts at a customer's facility. The workspace dimensions of this unit measure 22"W x 126"D x 15"H.
January 6, 2017
No. 876 is a 500º F gas-heated belt conveyor oven from Grieve, currently used for drying brass and aluminum parts at a customer's facility. The workspace dimensions of this unit measure 22"W x 126"D x 15"H. The workload rides through an 18" long open belt loading zone, 126" long insulated heat zone with recirculated airflow, 6" long open zone, 72" long cooling zone and a 12" long open unloading zone.
350,000 BTU/HR installed in a modulating natural gas burner heat the workspace, while a 3,000-CFM, 2-HP recirculating blower furnishes vertical downward airflow to the workload. This oven features an aluminized steel interior and exterior, 4" thick insulated walls and two 12" diameter tubeaxial fans, each driven by a motor to push/pull air through the cooling zone. A side oven door allows access to the heat chamber.
No. 876 includes a 16"W, B36-24-14 conveyor belt with 3"H flex plate edges, driven by a 1/3-HP motor with variable speed from 1.3 to 26 feet per minute.
All safety equipment required by IRI, FM and NFPA Standard 86 for gas-heated equipment is onboard, including a 325 CFM, 1/3-HP powered forced exhauster.
