Built with high-capacity motors for heavy-duty use and long cycles, the 8-inch bench grinder from Palmgren ensures smooth, quiet power grinding, cleaning, deburring, chamfering and sharpening jobs. Part of the Powergrind line of grinders, the 8-inch model (#9682081) is designed to handle all projects from heavy stock removal to finishing applications.
The Powergrind line features extended wheel-to-wheel clearance to easily handle longer items and large adjustable tool rests for safe, efficient tilt and angle grinding. CSA approved and OHSA compliant, the grinder also is available with 6, 7, 10 or 12-inch wheels. The grinder line comes with a 3-year warranty and is available in 1 phase and 3 phase models.
- chamfering
chamfering
- clearance
clearance
- grinding
