TDM Systems has expanded its Shopfloor Management under TDM Global Line. With the TDM Shopfloor Manager, the customer can individually build and illustrate the entire tool workflow on the shop floor.
“The days when a shopfloor had to adapt to rigid software are gone. Consistent and modular in design, the TDM Shopfloor Manager tool adapts to all circumstances in order-planning, configuration, as well as workflow for cribs, assembly, presetting, machine and secondary cribs,“ said, Volker Schwegler, senior product manager at TDM Systems.
No matter whether the users are dealing with orders, individual workpieces or NC programs, everything is broken down into tool lists and each person involved in a process can view the precise information required for the specific task.
Schwegler added, "Many companies combine tool assembly and presetting together in one tool room, for example, but with TDM Shopfloor Manager, the two areas can be combined to form a cost center and all actions can be combined into a single screen."
The software is freely configurable, without any need to adapt the programming. This flexibility also reduces an individual adjustment. At least 80 percent of user-needs can be covered as standard. However, too much flexibility could lead to faults if processes are compiled in the wrong sequence.
TDM Shopfloor Manager from is fully compatible with the stock management of the TDM Tool Crib Module Global Line. This means that even tool assemblies in secondary cribs and those near machines can be managed.
- numerical control ( NC)
