Sonopower Digital 3S Ultrasonic Cleaning System
With the Sonopower Digital 3S system for 25/50 kHz, Weber Ultrasonics presents an innovative ultrasonic solution that also enables the use of multifrequency ultrasound in vacuum chamber cleaning systems. The flexibility and range of possible applications of these systems is thus considerably increased.
April 13, 2016
The vacuum-tight submersible transducers with switchable ultrasonic frequencies of 25 and 50 kHz ensure an optimized cleaning effect for both coarse and fine cleaning. As a result, cleanliness specifications can be met efficiently and with a high level of process stability with a single unit, even with a changing or altered parts range. This advantage particularly pays off in component manufacturing in small batches, which previously often required two cleaning units.
  • ultrasonic cleaning
    Method of cleaning metal or plastic parts by immersing them in an aqueous or solvent-based cleaning solution and imposing ultrasound energy on the bath to enhance cleaning by creat…
