ToolGrind TC-X 620 Grinding Fluid
ToolGrind TC-X 620 is formulated with highly refined base oils that have very good viscosity and temperature characteristics combined with low misting and aromatic content. ToolGrind's fortified additive package allows the oil to perform well under extreme pressure.
ToolGrind TC-X 620 is formulated with highly refined base oils that have very good viscosity and temperature characteristics combined with low misting and aromatic content. ToolGrind's fortified additive package allows the oil to perform well under extreme pressure. Its active agents guarantee favorable cooling, wetting and lubrication. None of the additives contain chlorine, silicone or heavy metals and they are all nontoxic.
ToolGrind TC-X 620 promotes clean grinding wheels, low grinding temperature and less wheel wear.
ToolGrind TC-X 620 prohibits workpiece corrosion and is suitable for most filtration systems. The operative range of ToolGrind TC-X 620 covers all high-speed grinding operations, such as profile, groove and surface grinding, with CBN, diamond or silicon-carbide wheels. ToolGrind TC-X 620 is suitable for use with tungsten carbide, HSS, PCD, CBN, cermet and ceramics.
