![Tru Temp XT Process Forms a Black Oxide Finish on Various Metals Tru Temp XT Process Forms a Black Oxide Finish](/sites/default/files/styles/product_image/public/product_images/Birchwood1019.jpg?itok=l32nWgXp)
The new Tru Temp XT process forms a durable black oxide finish on difficult-to-blacken steel, iron and most stainless steel alloys. Long asked for by metal finishers, Tru Temp XT is a mid-temperature process that forms a satin black magnetite finish that protects critical surfaces in storage, shipment and startup while resisting galling and aiding break-in.
Operating at 230° 260°, Tru Temp XT is used as a two-stage chemical reaction, first using Oxyprime XT primer/prep, then followed by Tru Temp XT, which forms the attractive black magnetite finish. The process takes just 30 minutes. For optimal appearance and corrosion protection, the black finish can be sealed with an appropriate rust preventative topcoat.
The Tru Temp XT finish is Mil-Spec and RoHS compliant and withstands up to 120 hours of neutral salt spray or several hundred hours of humidity, verified by independent testing. The finish is a 0.5 microns thick (20 millionths) crystalline structure that allows it to effectively hold a rust inhibitor while serving as a sacrificial barrier to provide break-in lubricity and galling resistance. Critical parts are protected for storage or overseas shipment.
The answer to difficult-to-blacken steels, the Tru Temp XT process can be installed in most plant settings without compromising nearby equipment. The operating solutions contain no EPA regulated chemicals and process rinse waters can usually be sent to the sewer as non-hazardous discharge. Most process lines do not require waste treatment equipment.
Available in 1-, 5- and 55-gallon containers, Tru Temp XT is available online. In addition, complete Tru Temp XT process lines are available in many capacities to fit part size and production volume.
- alloys
alloys
- black oxide
black oxide
Black finish on a metal produced by immersing it in hot oxidizing salts or salt solutions.
- galling
galling
Condition whereby excessive friction between high spots results in localized welding with subsequent spalling and further roughening of the rubbing surface(s) of one or both of two mating parts.
- lubricity
lubricity
Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
