Vertical Toolroom Saw
The vertical toolroom saw from Palmgren is designed for contour sawing, beveling, slicing, ripping, stack cutting and cutting off.
The vertical toolroom saw from Palmgren is designed for contour sawing, beveling, slicing, ripping, stack cutting and cutting off. The combination of the variable speed drive, rugged unitized welded streel frame to minimize deflection and solid cast iron table makes it easy to cut many types of materials including aluminum, brass and tool steels.
Available in both 15-inch (#9683116) and 18-inch (#9683119) blade wheels, its variable-speed drive system permits quick, easy speed changes allowing the operator the match the correct speed to the blade and cutting application.
