Wheel profiling machine from CUMI
Published Date
August 28, 2018 - 12:00:pm
The CDM series wheel profiling machine from CUMI is ergonomically designed with operator friendly features for applications such as dressing and profiling of straight and convex diamond or CBN grinding wheels mounted on a wheel pack.
The CDM series comprises CDM 8V (with video vision) and CDM 8P (with profile projector) models, with features such as easy accessibility for operations, rigid design, linear bearings for slide movement, stress relieved castings, precision work and wheel spindle, and customized work spindle front nose. Optional features include variable speed for work and wheel spindle, motorized arrangement for work head axis, and linear scale with digital readout for work head axis.
  • cubic boron nitride ( CBN)
  • dressing
    dressing
  • grinding
  • profiling
    profiling
