Chatterfree Endmills
June 01, 2011
With a new level of built-in asymmetry, ISCAR EC-H CHATTERFREE solid carbide endmills bring a new level of speed and process security to slotting and shoulder milling of ferrous metals. On alloy and stainless steel, users report 20-25 percent longer tool life than with ordinary variable-pitch endmills. Familiar variable-pitch flutes have proven out for years for their vibration-dampening characteristics in solid carbide endmills.
Now ISCAR has gone one step better by varying the helixes as well. Two flutes have a 35-degree helix angle and the other two ascend at 37 degrees. ISCAR's theory is that the more asymmetry they design into a solid carbide tool, the greater its resistance to harmonic vibration and chatter. The variable helix adds one extra dampening influence against harmonic vibrations, a principal cause of tool fracture in hard but brittle solid carbide endmills. By the same mechanism it also further minimizes chatter marks in the workpiece.
EC-H CHATTERFREE endmills are available in the diameter range of 6-25mm, with either Weldon (relieved) or cylindrical (straight) shanks. All have corner radii and are made of IC900, the most versatile PVD coated grade available today. Besides defeating vibration, ISCAR EC-H CHATTERFREE endmills feature a free-cutting edge geometry that improves chip evacuation and reduces cutting forces, suiting them ideally for low power machines with ISO 40 or BT40 adaptations. With such improved control over vibration and cutting forces, they can safely be used on slots up to 2.5 x D in alloy and stainless steel.
Four-flute EC-H CHATTERFREE endmills come in three types: standard lengths with cylindrical shanks, standard lengths with relieved shanks and extra long 4 x D mills with cylindrical shanks. Two early applications underscore the added performance of the variable-helix/variable-flute endmill vs. standard variable-flute tool. In rough shoulder milling of an austenitic stainless steel workpiece, the material removal rate improved to 20.05 cm/min., from 9.17 with the tool change, and tool life improved to 45 pieces vs. 30, before flank wear necessitated replacement.
The main improvement with the EC-H cutter stemmed from doubling the depth of cut, which would have snapped off the competing tool. Also, in the case of a rough slotting operation with X6CrNiMoTi17-12-2, the EC-H CHATTERFREE endmill lasted through 60 pieces under identical conditions that had snapped off the competing endmill at 45 pieces.
  • chatter
    chatter
  • depth of cut
    depth of cut
  • endmill
    endmill
  • flank wear
    flank wear
  • flutes
    flutes
  • gang cutting ( milling)
  • helix angle
    helix angle
  • milling
  • physical vapor deposition ( PVD)
  • slotting
    slotting
    Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
Additional Products from Iscar USA
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
