CUT-GRIP Grooving Inserts
March 01, 2011
ISCAR has launched a line of improved CUT-GRIP grooving inserts for ID grooving that features the N-type chipformer that has proven so effective in OD turning of problematic metals. Internal groovers with the advanced chipformer are available for diameters down to 22mm (.866").
In OD grooving applications, the N-type chipformer has outperformed competitors in numerous automotive parts in steels that consistently prove excellent performance compared to other chipbreakers: 42CrMo4, 20MnCr5 38MnVS6, 1045 and 4340. Several Tier-One suppliers report that it begins to reliably break up chips at feed rates as low as 0.002 ipr. By switching from a J-type to an N-type chipformer, one manufacturer of pinion gears in a 4340-like steel virtually doubled both hourly output and tool life, and completely eliminated a chip disposal problem.
The expanded CUT-GRIP line includes double-ended GINI inserts for ID turning and grooving and new sizes of GIMN 302 inserts in grade IC907.
  • feed
  • grooving
    grooving
  • inner diameter ( ID)
  • outer diameter ( OD)
  • turning
Additional Products from Iscar USA
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
