HELIDO S865 FSN mill
October 01, 2010
Iscar Metals Inc. has expanded its popular HELIDO milling cutter family to optimize facemilling, especially for cast iron. The new HELIDO S865 FSN mill has a 65o lead angle to minimize burr formation and edge breakout, which can complicate cast iron applications. In addition, the HELIDO cutters feature positive axial rake to reduce cutting forces and power consumption at cutting depths up to 8mm. Double-sided HELIDO inserts have eight cutting edges for reduced tool cost per edge. Cutting edges are helical to decrease impact forces at entry and foster a cleaving-type cutting action. A 0.079" flat wiper behind the cutting edge helps impart a finer surface finish. New HELIDO 65o face milling cutters feature direct coolant delivery to each insert. They are available in standard and fine pitch, in sizes covering the diameter range 2.00" to 5.00".
  • axial rake
    axial rake
    On angular tool flutes, the angle between the tooth face and the axial plane through the tool point.
  • burr
    burr
  • coolant
  • facemilling
    facemilling
  • flat ( screw flat)
    flat ( screw flat)
  • gang cutting ( milling)
  • lead angle
    lead angle
    Angle between the side-cutting edge and the projected side of the tool shank or holder, which leads the cutting tool into the workpiece.
  • milling
  • milling cutter
    milling cutter
  • milling machine ( mill)
  • pitch
    pitch
  • rake
    rake
  • wiper
    wiper
Additional Products from Iscar USA
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
