HELITANG UPFEED
March 01, 2011
A new high-feed milling cutter extends the benefits of ISCAR's HELITANG UPFEED tangential milling cutters to ramping work as well. This Feed Mill has outstanding track record on Titanium and Stainless Steel Milling, according to the company.
In tangential milling, the insert lies flat in the pitch circle, presenting its strongest cross section to the main cutting force vector. This permits much faster feeds and deeper cuts without risk of sudden insert failure. It also enables stronger cutters and finer pitch in a given-size cutter. The practice was originated mainly for heavy rough machining and for unstable conditions on flat work only.
Key to the new ramping capability is the new ISCAR FTP insert. The geometry is modified just enough to allow ramping while retaining the proven high-feed capability of the TANGMILL line. It features the familiar double sides with four peripheral ground cutting edges plus a shallow 12.5 degree entering angle. In the cutter it fits rigidly into a standard tangential seat with dovetailed clamping. Inserts come with a choice of other edge geometries for standard work or ETR geometry for heavier, higher feed applications.
  • cutting force
    cutting force
  • feed
  • flat ( screw flat)
    flat ( screw flat)
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
  • milling machine ( mill)
  • pitch
    pitch
Additional Products from Iscar USA
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
