HM90 ADCT 1505 ...-CF Insert
September 13, 2013
The chatter or vibration in metal cutting poses an eternal challenge for manufacturers. The ISCAR products of the latest HIGH QLINE family of cutting tools offer an interesting solution: Indexable Milling Insert with an asymmetric shape. This insert opens up new opportunities for reduction of vibrations in metal cutting.
The design of the new one-sided insert HM90 ADCT ...-CF follows a different and unique approach compared to traditional Milling inserts in the Market. The insert has different Helix Angles on the two cutting edges and the two edges are colored gold and black. The concept is to mount gold and black edges alternately resulting in variable helix configuration for the cutter.
This feature ensures significant improvement of the cutters' performance in shoulder milling by reducing vibrations. Typically, the tool life of the insert increases by 15-20 percent and the power consumption is reduced by 10 percent or more.
This solution is ideally suited for:
1) Less rigid set-up.
2) Long overhang applications
3) Thin-walled workpieces
4) Problematic workholding.
It is important to note that the new asymmetric insert is suitable for already existing and popular Heli-Mil Family of Milling cutters.
Chatter has a complex nature. Simulating vibrations is difficult because it depends on many factors. In the design stage, simulation does not always help to find the geometry of a vibration-proof indexable milling cutter for broad-spectrum applications. Therefore, the ability of simple "cutter tuning" for a vibration-free mode only by changing the order of insert clamping looks very promising.
  • chatter
    chatter
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
Additional Products from Iscar USA
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
