IC806 Grade
February 12, 2012
ISCAR is introducing the IC806 — a new complementary SUMO TEC PVD coated grade for machining high temperature alloys, especially Inconel 718.
Inconel 718 belongs to a family of nickel based superalloys which are used extensively for applications where withstanding high temperatures and high corrosion resistance is required. This material is widely used in the aerospace industry for components which are placed in the hot section of the engine; and in additional sectors of the oil industry. The major problems encountered when machining Inconel 718 are characterized by very high temperatures on the cutting edge of the insert due to the abrasive elements in the material composition (high nickel content of 50-55 percent and chrome 17-21 percent) which causes high wear rates, chipping, notching and insert breakage.
These factors contribute to reduced tool life and high deformation of the cutting edge even at low cutting speeds. ISCAR's aim is to effectively machine this unique material, and has therefore successfully developed the IC806, which is a submicron grade with superior wear resistant properties and advanced PVD TiAlN.
IC806 has a hard submicron substrate with PVD coating and a special post coating treatment which provides substantially improved tool life and better reliability.
  • abrasive
    abrasive
  • alloys
    alloys
  • corrosion resistance
  • physical vapor deposition ( PVD)
  • superalloys
    superalloys
  • titanium aluminum nitride ( TiAlN)
    Often used as a tool coating. AlTiN indicates the aluminum content is greater than the titanium. See coated tools.
Additional Products from Iscar USA
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
