PCHPRL Square-Shank Toolholder
June 01, 2011
June 2011 — ISCAR's new perpendicular toolholder makes it easier to fit PENTACUT 24 grooving and parting tools into overcrowded turrets in high-volume turning operations. It holds the same popular PENTACUT five-edged grooving and parting tool, but from a different angle.
The PCHPRL square-shank toolholder clamps the PENTACUT insert perpendicular to its axis, so the shank can line up with the spindle's centerline. This creates more tool presentation options and can eliminate interference issues in some setups. Popular and proven for years, the star-shaped PENTACUT parting insert provides five straight indexable cutting edges with several types of chipformers.
The combination of a very secure clamping system and strong insert design enables grooving, parting, recessing and chamfering. Users report straighter sidewalls and flatter groove bottoms. Due to the star-shaped design, the insert survives despite failure on one edge. The other four edges remain intact and useable, leading to much lower tooling labor and inventory costs.
Three toolholder sizes are available in the perpendicular arrangement: 16, 20 and 24mm cross sections. The new tools are suitable for regular turret machines, perpendicular orientation and gang/turret type CNC lathe machines.
  • chamfering
    chamfering
  • grooving
    grooving
  • lathe
    lathe
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
  • recessing
    recessing
    A turning operation in which a groove is produced on the periphery or inside a hole of a workpiece. The grooving tool moves at right angles to the axis of rotation.
  • shank
    shank
  • toolholder
    toolholder
  • turning
Additional Products from Iscar USA
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
