Railcar-Wheel Tools
June 01, 2011
A new family of innovative turning tools from ISCAR raises the threshold for process security in difficult railroad-wheel reconditioning work. Users report reliably longer tool life by 66 to 250 percent when re-turning hardened alloy steel railroad wheels, even on cracked rim areas that can wreck ordinary tools. They also report uniformly smaller, more manageable chips.
The new ISCAR tools withstand the punishment better due to their tangential design. The insert is oriented tangential to the direction of cut, which aligns its strongest cross section to the main cutting force vector. This dramatically reduces the risk of sudden, premature edge rupture and resulting chronic production stoppages. It also leads to stronger cutter bodies, making the entire cutting system more rigid and secure. Even when roughing a wheel with a 12mm depth of cut on a cracked surface, the tool lasts reliably longer. The edge wears down gradually and predictably, rather than fracturing, reducing the need for operator attendance.
The ISCAR railcar-wheel tool family includes inserts and cartridge-type toolholders able to complete the entire wheel profile in a single pass on any mainstream rail-wheel reconditioning machine. They work as drop-in replacements for conventional tools, not even requiring any new tool offset. Each tool holds two inserts oriented differently, to reach every part of the profile. The inserts come in four grades to match all cutting conditions, from roughing cracked wheels on an unstable machine to finishing on a tight one. All inserts feature aggressive WM chipbreaker top-face geometries to eject hot chips, minimize re-cutting and keep the operation running cooler. They have been especially effective in breaking up long chips during rim turning.
ISCAR recommends insert grades IC8150/IC9150 for finishing under stable conditions, and IC8250/IC9250 for semi-finishing and finishing under unstable conditions. In one application on a Rafamet under-floor machine, ISCAR ISOTURN tangential tools improved tool life from 40 to 72 pieces despite increasing the feed rate by nearly 100 percent. On a Hegenscheidt-under floor machine under identical conditions, a drop-in switch to the new ISCAR tools more than doubled tool life to 30 pieces, from 12.
  • chipbreaker
    chipbreaker
    Groove or other tool geometry that breaks chips into small fragments as they come off the workpiece. Designed to prevent chips from becoming so long that they are difficult to control, catch in turning parts and cause safety problems.
  • cutting force
    cutting force
  • depth of cut
    depth of cut
  • feed
  • reaction injection molding ( RIM)
    Molding process that allows the rapid molding of liquid materials. The injection-molding process consists of heating and homogenizing plastic granules in a cylinder until they are sufficiently fluid to allow for pressure injection into a relatively cold mold, where they solidify and take the shape of the mold cavity. For thermoplastics, no chemical changes occur within the plastic, and, consequently, the process is repeatable. The major advantages of the injection-molding process are the speed of production; minimal requirements for postmolding operations; and simultaneous, multipart molding.
  • turning
Additional Products from Iscar USA
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
