SD-SP15 Slotting and Groove Milling Cutters
January 01, 2014
ISCAR is introducing the SD-SP15, a new family of narrow slotting and groove milling cutters, featuring 1.25" diameter milling heads with 8 teeth in a width range of .125" — .250" for maximum depth of cut up to .315".
The new cutters consist of interchangeable solid carbide T-slot milling heads and cylindrical steel shanks assembled by means of a unique spline connection. Also available is an adapter with the SP spline connection on one side and T12 MULTI-MASTER threaded connection on the other side, which enables using all T12 standard MULTI-MASTER shanks.
The spline connection is used to transmit the torque in the best way. It ensures very durable assembly to withstand considerable cutting forces during slot milling and bending forces caused by long reach overhang. The spline connection designation is SP15, where "15" indicates the connection size.
The general-duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials. The cutter heads feature an SP15 internal spline mounted on a matching external spline on the shank secured by a central screw.
The new heads are made from the versatile IC908 grade and they are based on the successful cutting geometry of themm-TS MULTI-MASTER heads.
  • depth of cut
    depth of cut
  • gang cutting ( milling)
  • milling
  • shank
    shank
  • slotting
    slotting
    Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
Additional Products from Iscar USA
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
