Tiger-IQ Grooving Tools
January 01, 2014
The DOVEIQGRIP line from Iscar Metals is an evolution of the successful TIGER wide grooving inserts family. The new line features a unique user-friendly locking mechanism designed for inserts in widths of 10, 12, 14, 16, 18 and 20mm and is made from SUMO TEC grade IC808.
The inserts can be mounted on integral shank tools or on blades with cartridges that provide additional security for the blades.
The integral shank tools are available in 25, 32 and 40mm square shanks. The cartridges were designed for 10, 12 and 14mm width inserts, mounted on 53mm blade size.
The new system provides excellent performance in deep, wide and heavy grooving operations.
Advantages include:
Very rigid dovetail clamping.
Unique, user-friendly (patented) frontal locking mechanism. Just a half-turn to lock the insert. In addition, there is no risk of falling parts, as there is no need to fully extract the screw, as in most available systems.
Unobstructed chip flow, because the tool has no upper clamp or jaw. Normally in grooving (especially in deep grooving), the chip flow prevents the coolant from reaching the cutting edge. ISCAR's new tools have a bottom frontal coolant K-type system (high pressure possible). This substantially prolongs tool life and improves chip formation.
The DOVEIQGRIP blades carry cartridges attached by a dovetail connection, providing very high rigidity. The system was designed so that in case of crash during machining, only the cartridge will be damaged. The cartridges also provide an economical protection solution, thus prolonging service life of the blades. The cartridge system can also be used for specials and exchangeable heads, providing savings on expensive tool cost.
  • coolant
  • grooving
    grooving
  • shank
    shank
Additional Products from Iscar USA
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
