Burton Mill Solutions acquires bandsaw blade weld center
Burton Mill Solutions has acquired Oregon Industrial. Burton will be able to supply metal cutting bands that meet factory specifications for tough metals and abrasive surfaces.
November 11, 2024
Burton Mill Solutions has acquired Oregon Industrial, based in Eugene, Oregon.
Oregon Industrial is a bandsaw blade weld center, specializing in precision tooth matching for nearly 90 years. This acquisition expands Burton Mill Solutions' ability to continue pushing the boundaries of excellence in custom cutting tools.
The company said that thanks to this new team of expert welders, Burton will be able to supply metal cutting bands that meet the most stringent factory specifications for tough metals and abrasive surfaces. The continued use of the same state-of-the-art equipment and the same experienced Oregon Industrial professionals will ensure the same exceptional quality and service.
"We are delighted to join forces with Oregon Industrial Bandsaw. The addition of the narrow band welding service, and all the employees that have contributed to its success, will allow us to better serve the secondary markets in the U.S. West," said senior vice president Chuck Wert.
As part of this transition, Oregon Industrial will be relocating to the Burton Mill Solutions facility across town in Springfield, Oregon, where it will be integrated into existing operations to the benefit of existing and future customers.
  • abrasive
    Substance used for grinding, honing, lapping, superfinishing and polishing. Examples include garnet, emery, corundum, silicon carbide, cubic boron nitride and diamond in various gr…
  • bandsaw
    Machine that utilizes an endless band, normally with serrated teeth, for cutoff or contour sawing. See saw, sawing machine.
  • chuck
    Workholding device that affixes to a mill, lathe or drill-press spindle. It holds a tool or workpiece by one end, allowing it to be rotated. May also be fitted to the machine table…
