ZCC USA showcases its efficient cutting tools, including solid drills and milling products. New for 2024 are the GMX Series Universal End Mills and XML-12 high-feed mills, designed to enhance material removal efficiency. The company also introduces chip breakers and high-efficiency milling cutters for improved tool longevity, along with the YBH053 turning grade for hardened materials and the FMR11 milling cutter series for fast material removal. ZCC USA celebrates 20 years in the American market.
- milling cutter
milling cutter
- turning
