Contract manufacturer invests in fourth Starrag machine
Of all businesses, contract machining companies know what they want: Cincinnati-based firm Metalex Manufacturing Inc. already owns three Starrag machine tools, but after extensive benchmarking, the key customer has chosen to invest in a Droop+Rein T portal machining center from Starrag—its largest investment to date in every respect.
Article provided by Starrag
The contract machining company, a specialist in producing sophisticated and high-quality workpieces, was looking for a machine that was capable of machining a variety of materials with flexibility, efficiency and precision—all in a single clamping operation. This was where Starrag's claim came into play once again. In keeping with the proven philosophy of "Engineering precisely what you value," Metalex and a team from Starrag turned their attention to the entire Starrag portfolio.
For its new Center for Advanced Large Manufacturing, Metalex, based in Cincinnati, ordered a 6-axis portal machining center from the Droop+Rein T series by Starrag. Graphics: Starrag
The company ultimately decided on the Droop+Rein T series from the Bielefeld site—a mill/turn center offering an outstanding level of accuracy thanks to its rigid design and hydrostatic guide concept. Just one look at the extraordinary dimensions (table length: 709 inch; horizontal pass: 354 inch; vertical pass: 276 inch) and the working area of X: 748 inch; Y: 354 inch; Z: 118 inch proves it: The huge amount of space offered by this new model means that processing large workpieces in a single clamping operation is easy. There is also an option for highly flexible 5-axis processing thanks to the integrated C-axis with stepless rotation and the universal fork-type milling head, featuring a B-axis that swivels ±203° F. The sixth-axis (W)—a 217 inch continuously movable crossbeam—complemented the universal approach that the contract machining company required.
The machining center uses a 134-hp main spindle with a maximum torque of 66,372 lbf in, transmitted via vertical and horizontal milling heads; two fork-type milling heads designed for 5-axis operation, as well as a slim outboard bearing for drilling through. If entirely new orders come in, there is an option to use additional heads for milling, turning, grinding and turning. The versatile robot magazine, which has space for up to 400 tools, supplies the milling and turning heads with three different tool systems. Integration into Metalex's production and tool management systems is undertaken by the Integrated Production System (IPS), Starrag's "building block" for Industry 4.0 solutions.
The special table construction with two large tables (236 x 315 inch) ensures efficient machining. This construction means that one table can be used under the spindle while the other is loaded and unloaded outside the work area. Extra-long workpieces are machined in coupled tandem operation, for which tables are extended to 709 inch. Each table also features an integrated rotary table from the Dörries series (diameter: 236 inch). Thanks to the two 149-hp main drives, the turning of components weighing up to 440,925 lbs. is also possible. The rotary table can also be used as a C-axis for precise positioning when milling and drilling.
All in all, Starrag's solution was exactly what Kevin Kummerle was looking for. The CEO of Metalex values healthy growth and continuous development. The new Droop+Rein T portal machining center plays an important part in this, offering Metalex and its customers impressive long-term benefits in terms of quality, technology, costs and service.
