Tungaloy Promotions 2024
Published Date
February 01, 2024 - 08:35:am
Take advantage of discounted pricing and special offers on all of our best-performing milling, grooving, turning, parting, threading, and drilling tools!
https://tungaloy.com/us/promotions/
  • gang cutting ( milling)
  • grooving
    grooving
  • milling
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
  • threading
    threading
  • turning
