BENZ releases new tooling catalogs
October 12, 2014 - 07:00pm
BENZ Inc., Charlotte, N.C., has released new catalogs for its Solidfix, CAPTO and Trifix modular quick-change tooling systems.
BENZ Inc., Charlotte, N.C., has released new catalogs for its Solidfix, CAPTO and Trifix modular quick-change tooling systems. BENZ specializes in tooling systems for turning and milling machines such as live and static tools, angle heads, multi-spindle heads, spindle speeders, large scale drill heads, 5-axis heads, and its lines of modular tooling systems. BENZ tooling systems are engineered in Germany and sold and serviced in the U.S. and Canada by Benz Inc.
BENZ has published a 60-page catalog for its latest proprietary modular tooling system, the Solidfix line. The new system reduces setup times for tools by up to 90 percent with 15 second tool changes, according to the company.
Another new catalog details BENZ's CAPTO modular quick-change system, which features a compact design that can be used for milling, drilling and turning with up to 100 bar coolant pressure.
BENZ also released a catalog featuring LinTec push-type broaching tools, which the company says provide a range of additional machining processes, such as torx, internal and external splines, involute gears/shafts, hexagon sockets and grooves.
Each full-color catalog provides product descriptions, technical specifications and parts breakdown, complete with product ordering information, inquiry forms, and available options and tooling accessories data. To download electronic versions of each catalog, visit www.benz-inc.com, or request a hard copy by calling (704) 529-5300.
  • broaching
    broaching
    Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
  • coolant
  • gang cutting ( milling)
  • milling
  • modular tooling
    modular tooling
    1. Tooling system comprised of standardized tools and toolholders. 2. Devices that allow rapid mounting and replacement of tools. Commonly used with carousel toolchangers and other computerized machining operations. See toolchanger; toolholder.
  • turning
