Harvey Performance Co. LLC partners with Autodesk Inc.
October 01, 2018 - 04:45pm
Harvey Performance Co. LLCROWLEY, MA (August 29, 2018) – Harvey Performance Company is proud to announce, effective immediately, the entire end mill tool libraries for both Harvey Tool and Helical Solutions, representing more than 14,000 SKU’s, are available to upload into Autodesk’s Fusion 360 CAM Software. This new partnership between Harvey Performance Company’s leading cutting tool brands and Autodesk eliminates the need for machinists to manually build Harvey Tool and Helical Solutions tools for projects programmed with their Fusion 360 CAM program, resulting in substantial time savings.
Autodesk Partnership Overview
         All Harvey Tool and Helical Solutions end mills are now available to download and easily import into Autodesk’s Fusion 360 software.
         Comprehensive dimensional and required geometrical data, data users would otherwise be required to measure themselves, is now available for more than 14,000 tools.
         Speeds and feeds information is not prepopulated, allowing users to determine the appropriate running parameters for their specific job and machining setups.
         Harvey Tool and Helical Solutions will continue to add more tool libraries for import into the Fusion 360 CAM software over the next several months. Future updates will include Harvey Tool specialty profiles and drills, as well as Helical Solutions Chamfer Mills.
“Before our partnership with Autodesk, Fusion 360 users would have to manually import the tool’s .DXF from the Harvey Tool or Helical Solutions websites, or edit the tool in the software, defining all of the dimensions of our tools,” said Harvey Performance Company Technical Development Engineer David Pichette. “Through this partnership, tools available for download will already have all of the necessary tool dimensions and required geometries defined. The customer can confidently import them directly from their download folder into Fusion 360, add them to the job they are working on, and eliminate a big chunk of time-consuming work.”
“We feel our partnership with Autodesk is a tremendous advantage for our customers and consistent with how we strive to delight our customers,” said Harvey Performance Company Vice President of Engineering Jeff Davis. “Not only do we process orders and ship tools same-day to provide a time advantage, but even programming a job is faster now. This is just another example of Harvey Performance Company going the extra mile.”
  • milling machine ( mill)
Metal Supermarkets, a supplier of small-quantity metals, named the six winners of its 10th annual Metal My Way contest.
11/13/2024
Swiss tooling company REGO-FIX welcomed attendees and manufacturing partners from across the globe for a day-long grand opening celebration of the company’s Center for Machining Excellence (CME). The…
11/08/2024
Since May 2024, Intercable Tools GmbH, a more than 50-year-old manufacturer of connection technology and tools, has been using ultrasonic deburring technology from the German company UltraTEC…
