Platinum Tooling, a Prospect Heights, Ill.-based distributor of live tools, angle heads, Swiss machine products, and knurling and marking tools manufactured by various international suppliers, now offers Rineck shrink-fit tooling and shrink-fit machine technology for customers in the United States and Mexico.
Established in 1966, Rineck started as a job shop for small parts, then became a producer of hydraulic parts for the mining industry, and is now a globally recognized manufacturer of tool-holding technology. Rineck’s investment in state-of-the-art manufacturing equipment and commitment to innovation, research, and development allows them to constantly look for ways to achieve the optimal balance of quality, consistency, and affordability.
Rineck offers standard and custom shrink-fit tool holders with various connections including CAT, HSK, BT, SK, PSC, and straight shank extensions. In addition, ER shrink-fit collets are available. For added rigidity, flange or dual contact holders are available for CAT and BT tapers. A clamping range from 3 mm to 32 mm is possible for both slim and standard styles. All tools are available in inch and metric sizes.
Rineck produces a range of standard shrink-fit tool holders as well as custom tooling. In addition to standard 4.5-degree taper tools, 3-degree slim and extra-slim tools are available. Most holders come standard with length-adjusting screws. Coolant delivery to the cutting tool can be achieved either through the center or flange of the tool holder utilizing coolant jets or slots.
In addition to shrink-fit tool holders, Platinum Tooling will offer shrink-fit machine technology.
Equipped with an elevation cooling system, heated tools can be moved to a cooling tank with a push of a button. The machine’s smart design keeps accessories stored but close at hand during operation.
For this new line of shrink-fit tooling and machine technology, Platinum Tooling will handle application engineering, sales, and service through a network of distributors across the United States and Mexico.
- coolant
- knurling
knurling
Chipless material-displacement process that is usually accomplished on a lathe by forcing a knurling die into the surface of a rotating workpiece to create a pattern. Knurling is often performed to create a decorative or gripping surface and repair undersized shafts.
- shank
shank
