Texas machine shop overcomes the heat
April 05, 2019 - 09:30am
Article from Portacool LLC
Greg Olson is the heavy machine shop supervisor at Washington Iron Works, Sherman, Texas. As a supervisor of a 12-person crew working on everything from crankshaft services to engine overhauls for oil and gas customers, he knows attention to detail is important. However, when Texas temps are pushing 90 degrees F in the shade and the sun is beating down on the metal shop, concentrating on details can be tough. The following is his description of how the shop found a solution.
Our heavy machine shop is one of Sherman, Texas’ oldest buildings, which was built in the late 1800s. It is a massive metal building without much insulation, and in the summer, it cooks. Getting air conditioning installed wouldn’t be too practical given how open it is, the height of the ceiling and how often the outside doors to the shop must be opened. Knowing A/C wasn’t an option, we tried shop fans. They blew a decent amount of air, but didn’t really cut it because they just blew hot air around.
I had seen evaporative coolers but I wasn’t sure my bosses would go for it because the coolers use water and any humidity could rust our key components. Corrosion in the shop can’t be tolerated. Because you can use evaporative coolers with the shop doors open, I started telling management we should give it a try. To say they were hesitant is an understatement. Water equaled rust to them - period.
At the time though, the heat was unbearable and made it harder for my guys to stay focused and productive – not to mention safe – with sweat and exhaustion from the hot conditions.
I finally suggested that we ask a local distributor to bring one of the new Portacool Jetstreams up to the shop, show us how to work it and let us test it out. To our amazement, we found we absolutely could get cold air in the shop from the Portacool evaporative cooler without putting rust-building humidity out. The guys that demoed the product helped us understand that Portacool evaporative coolers come with a water control valve that can be used to turn-down the amount of water running over the evaporative media in the back of the cooler. Bingo! That was the trick to making sure we didn’t have any rust issues.
It took some trial and error with the evaporative cooler. We used it the first couple of days and realized we had too much water running, so we kept adjusting the water flow until we found the exact setting that worked for our shop. It kept us cool and we were not seeing any rust on our equipment.
Now, we run the coolers about 10 to 12 hours a day. We have placed them in two corners of the shop to help create a directional airflow and the third by the main outside shop doors. By doing this, we’ve gotten great circulation across the building. It has even worked better to do that than placing the cooler where it shoots cool air directly on one person or area.
And, again we’ve had no issues with rust or corrosion of any kind. One of the Jetstream evaporative coolers points directly at our metal assembly table and has caused no rust and another one runs right next to the ways for one of our lathes and has caused no rust there as well. So, we’re happy and our machinery is intact and rust free. We’re sold on the cooling power. It’s made a huge difference in keeping a comfortable work environment.
HII, the McClean, Va.-based weapons developer, announced that its MissionTechnologies division was awarded a $209 million contract to support the development and sustainment of the U.S. Air Force’s (…
08/29/2024
At the 2024 IMTS Show, EasyCMM will showcase its Chameleon retrofit CMM motion controller and Mediator CMM software at Booth #134750 in the East Building at McCormick Place, Chicago.
08/28/2024
FABTECH, a metal forming, fabricating, welding, and finishing event will occur in Orlando from October 15-17. This year’s special events, which are free to all attendees unless noted, will feature a…
