25mm Fiberglass-Reinforced Auto-lock Utility Knife (XH-AL)
The OLFA XH-AL is designed with a cushioned rubber grip on a chemical-resistant handle for long lasting use. It features a stainless steel blade channel that extends the full length of the knife to support heavy-duty cutting for industrial materials such as gaskets, flexible conduit, belt synthetics, rope, laminates, plastics, fiberglass and rubber.
Each 25mm OLFA Snap-Blade contains seven Ultra-Sharp cutting edges per blade. Best of all, each new cutting edge is quickly accessible without ever having to fumble with a blade change. Simply snap off the blade for a fresh cutting edge. Changing out full blades on the XH-AL is quick, easy, and tool free.
