3851 Sandflex Cobra Bandsaw Blade
Bahco's new 3851 Sandflex Cobra bandsaw blade, with a powdered metal M42 high-speed steel tooth edge for higher hardness and added toughness, provides smooth, precise cuts for general-purpose and production-cutting applications.
The new geometry of the blade's variable teeth pattern is mathematically formulated to maximize cutting, resulting in less friction and vibration for improved performance.
The new 3851 Sandflex Cobra bandsaw blade is also engineered for contour cutting, including aluminum and stainless steel.
Benefits of the new 3851 Sandflex Cobra bandsaw blade include:
- Hook and combo style blades
- Hook – traditional tooth design with 10° rake angle, used for nonferrous metals, wood and plastics.
- Combo – new tooth geometry with variable teeth 8° to 10° rake angle for enhanced performance.
- Harder teeth but less prone to chipping
- New stronger tooth design for material penetration and improved blade life
- Complete assortment range: 1/4" to 3-1/8"
- Offering solutions for numerous general-purpose and production-cutting applications
