#9680185 8.5-in. x 27-in. Vertical Machining Center
#9680185 8.5-in. x 27-in. Vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">Machining Center
The 8.5-in. x 27-in. vertical machining center provides an economical solution for machining small parts. An automatic toolchanger and eight-tool magazine make the machining center ideally suited for prototyping and short run shops.
The 8.5-in. x 27-in. vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">machining center provides an economical solution for machining small parts. An automatic toolchanger and eight-tool magazine make the machining center ideally suited for prototyping and short run shops.
Standard features on the #9680185 include linear guide, servodrives and ballscrews on all three axes; safety switches on all doors for improved safety while machining and a central lubricating system to deliver oil to guide ways and ballscrews.
