Adaptix Soft Jaw
Adaptix Soft Jaw
The Adaptix Soft Jaw uses adjustable fingers and interchangeable tips to grip a wide variety of parts or workpieces during the computer numerical control (CNC) machining process. It was specially engineered to be a one-size-fits-all alternative to standard, single-application aluminum soft jaws.
September 9, 2021
As manufacturing plants struggle to meet demand due to industry-wide challenges, workers are looking for revolutionary yet easy-to-implement tools that can elicit a ripple effect of positive, efficiency-enhancing changes.
For the workholding industry in particular, the Adaptix Soft Jaw could be one of these tools.
Engineered by IMI Precision Engineering's new Norgren Workholding group, Adaptix is a malleable soft jaw that uses adjustable fingers and interchangeable tips to grip uniquely shaped parts. Because Adaptix can be adjusted, locked in place, and reset in a matter of minutes, machinists using this tool no longer need to manufacture single-application aluminum soft jaws before milling each new part.
Adaptix has the potential to save countless resources throughout the computer numerical control (CNC) machining workflow including time, raw materials like aluminum, and storage space that would otherwise be devoted to single-application soft jaws. Truly one part with infinite possibilities, Adaptix can help establish a safer, more efficient, and more sustainable operating model for a 21st century machining industry.
The Adaptix™ Soft Jaw uses adjustable fingers and interchangeable tips to grip a wide variety of parts or workpieces during the computer numerical control (CNC) machining process. It was specially engineered to be a one-size-fits-all alternative to standard, single-application aluminum soft jaws.
"Single-application soft jaws require a significant amount of time, skill and raw material to construct, even before a single part is milled," said Tom Wood, Senior Director of Growth Initiatives at Norgren. "We saw an opportunity to solve several machining problems with just one tool, and so we designed the Adaptix™ Soft Jaw to grip nearly any part with comparable repeatability and clamping force as single-application soft jaws. This singular innovation in the CNC machining workflow can have a huge impact on several pain points in the industry."
The Adaptix™ Soft Jaw's adjustable fingers and interchangeable tips are made out of a variety of different materials to match the milling needs of a particular part. The fingers easily mold into place to conform to the shape of the target part and then are locked in place. This configuration process takes minutes, instead of hours, on average, with traditional soft jaws. The soft jaw fits directly onto a vise, and is currently compatible with Kurt and Schunk brand vises, with other vise compatibility planned in the near future.
"The COVID-19 pandemic and the pressure it placed on supply chains, hiring needs, and skills training only exacerbated the existing needs of the machining industry," said Wood. "Adaptix™ and, by extension, Norgren Workholding were created by Norgren to leverage our commitment to breakthrough engineering to make manufacturing more streamlined and accessible, and to solve several industry bottlenecks."
  • computer numerical control (CNC)
    Microprocessor-based controller dedicated to a machine tool that permits the creation or modification of parts. Programmed numerical control activates the machine’s servos and spin…
