AGN4 Angular Wheelhead CNC Grinder
The AGN4 angular wheelhead CNC grinding machine from Weldon Solutions has been designed to produce high precision small parts and is capable of performing plunge, contour and traverse grinding operations. This compact machine occupies only 30 sq. ft. of floor space, but its standard configuration makes it adaptable for factory automation.
The AGN4 angular wheelhead CNC grinding machine from Weldon Solutions has been designed to produce high precision small parts and is capable of performing plunge, contour and traverse grinding operations. This compact machine occupies only 30 sq. ft. of floor space, but its standard configuration makes it adaptable for factory automation. The fully enclosed grinder is available with either a straight or 30° angular wheelhead.
The grinder is equipped with a combination live/dead spindle workhead for versatility. Highly rigid hydrodynamic wheel spindle bearings assure superior accuracy and smooth surface finishes.
A FANUC CNC is standard on the AGN4. Available options include an automatic loader, in-process OD gauge, automatic lateral locator and various wheel dressers.
