APS-438 Air-Powered Saw introduced
A pneumatic saw and quick-clamp assembly that lets users cut steel plate up to 2" thick and 15' wide anywhere there is a 90-psi compressed air supply is available from ESCO Tool.
July 1, 2010
A pneumatic saw and quick-clamp assembly that lets users cut steel plate up to 2" thick and 15' wide anywhere there is a 90-psi compressed air supply is available from ESCO Tool. ESCO's APS-438 air-powered Saw and Quick-Clamp lets workers take the saw to the steel plate rather than transporting the plate to a large table saw and can produce square cuts with no HAZ. Featuring a 2"-wide steel track with two wedge-style clamps for attaching to the plate, the pneumatic saw mounts on a bracket that glides along the track using four V-grooved steel wheels. Providing a cut line indicator gage to simplify setup and alignment, the Quick-Clamp's track comes in 5' to 15' sections. The saw is powered by a 3-hp motor. It square-cuts steel plate using fiberglass-reinforced blades and is also suited for cutting boiler tube panels up to 4" thick. The saw and Quick-Clamp sell for $5,795.00 (list) and are available for rent in the continental USA.
