BiCut SuperCuts
BiCut SuperCuts
Wiha's new BiCut SuperCuts are available in three styles; Soft Grip, Two Component Industrial SoftGrip and 1000-volt Insulated Industrial Cushion Grip.
Wiha's new BiCut SuperCuts are available in three styles; Soft Grip, Two Component Industrial SoftGrip and 1000-volt Insulated Industrial Cushion Grip. 200mm/8.0" BiCut SuperCuts are made of premium C70 tool steel, induction hardened for longest tool life.
BiCut SuperCuts completes the job of two pairs of pliers. Up to 50 percent less hand strength required for cutting. Cutting force doubled for extremely hard materials, up to 2mm (.080") spring wire. Easily switch between two strengths in one-handed operation. For cutting various materials from soft to extremely hard, such as nails, screws, bolts, wire cables, spring wires and chains.
