CAMWorks 2011
CAMWorks 2011
Geometric Technologies Inc. has announced the release of CAMWorks 2011, the latest version of its solid-based CNC programming solution.
February 1, 2011
CAMWorks 2011 is intended to be a more focused upgrade in the CAMWorks line and provide significant new capabilities including enhanced automation, improved knowledge-based machining information, smarter toolpaths, and more.
CAMWorks 2011 introduces VoluMill the ultra high-performance toolpath plug-in engine for high speed milling for 2.5 axis and 3 axis roughing operations. It is ideal for prismatic parts and complex 3-D shapes as its algorithms result in more intelligent toolpaths to machine pockets, slots, and arbitrary shapes. It can be used with any material, including the hardest metals. The result is increased efficiency and utilization of machines, tools, labor and materials.
For the mold and die industry, Geometric has introduced an optional electrode design solution labeled ElectrodeWorks that automates all aspects of the calculation and design of EDM electrodes including design, management, documentation and manufacturing. Its seamless integration with SolidWorks/CAMWorksSolids assures complete parametric association of data, according to the company.
Feature Recognition, which is used to automatically identify areas to be machined, has been upgraded to find more features, while decreasing computation times by more than 50 percent over previous CAMWorks versions. As part models become increasingly complex, recognizing more features in less time represents huge time savings for the NC programmer. The proprietary Technology Database (TechDB) that is used to store and apply knowledge based machining information, has been enhanced to simplify the process of creating best machining practices. The improved interaction will result in greater use of the knowledge-based machining capabilities of CAMWorks, and will reduce potential errors in machining information. Additional enhancements with CAMWorks 2011 include improved performance and enhanced feature recognition of slot features with fillet and taper as well as slots with islands.
Users can now define customized turn inserts when it is not possible to completely machine a turn part using a standard turn insert line diamond, square, etc. Such custom turn inserts can be defined for inner as well as outer diameter. And while earlier versions of CAMWorks did not provide flexibility to define work-in-process for turning operations, CAMWorks 2011 provides the user with the option to define the operation to be considered as the work-in-process within the entire operation.
  • 3-D
