CNC 8060 T Lathe
CNC 8060 T Lathe
The CNC 8060 T from Fagor Automation USA is a product adapted to the requirements of production lathes, high-speed machining centers or machines demanding high accuracy and high-end features.
September 28, 2016
Advances to make your job easier:
  • Touch screen
  • High definition graphics
  • More than 500 Mb of memory as standard in all CNC models, expandable via Compact Flash.
  • Free simulator on PC
  • Pop-up-based browsing (Fagor exclusive)
High-speed machining:
  • HSSA (High Speed Surface Accuracy) machining system (Fagor exclusive)
  • Nanometric accuracy, splines, etc.
  • Automatic tool management in long machining operations
Choose from four programming methods:
  • Standard ISO language
  • Parametric language
  • ProGTL3 language
  • IIP interactive language (Interactive Icon-based Pages)
  • Also supporting CAD/CAM programs and programs generated by other CNCs
A variety of canned cycles for milling and turning:
  • Many turning cycles.
  • Many facing cycles.
  • Wide selection of drilling and threading cycles.
  • Constant-pitch and variable-pitch threading.
  • Wide selection of threading cycles.
  • Many grooving cycles.
  • Profile cycle along the X axis.
  • Profile cycle along the Z axis.
  • Pocket cycles in the XC, ZC planes.
  • Pocket cycles in the XY, YZ planes.
  • Multiple pocket cycles.
  • 2D pockets for user-defined shapes.
