CNC Carbide Cold Saws
Its heavy-duty construction, combined with the CNC control, means greater rigidity with reduced vibration at higher cutting rates. The Carbide Cold Saws stand out for their exceptional accuracy, superior surface finish and increased blade life.
May 20, 2022
Incorporating advanced metal cutting technology into its line of cold saws, the CNC Carbide Saw from Palmgren provides full automation for intricate and precise fast cuts. The saws can cut more parts per hour as well as more parts per blade that any other standard saw on the market. In addition, its heavy-duty construction, combined with the CNC control, means greater rigidity with reduced vibration at higher cutting rates. The Carbide Cold Saws stand out for their exceptional accuracy, superior surface finish and increased blade life.
