CNC Slant Bed Lathes
The lathe's small size and footprint make it an excellent option for machine shops needing a second-op machine or additional chuck. Every bed lathe is manufactured and tested to ensure it meets the highest quality and accuracy standards.
The 5-inch CNC Slant Bed Lathe from Palmgren is a turning center designed specifically for production, short runs, one-offs and prototyping. It is an economical solution for machining small parts. The lathe's small size and footprint make it an excellent option for machine shops needing a second-op machine or additional chuck. Every bed lathe is manufactured and tested to ensure it meets the highest quality and accuracy standards. The rigid construction guarantees accuracy and repeatability. Each lathe features a Siemens 808 control which operators, especially entry level ones find easy to use. The lathe is also available in an 8-inch model.
