CNC Vertical Turret Milling Machines
The milling machines produce more parts, faster and with better tolerances than standard manual machines. In addition, they are simple to set up and operate. Another key feature is the Fagor Automatic controls that offer the most cost-effective solution in chip making profitability. This combination ensures faster programming, set-up and machining.
July 3, 2020
Designed for more complex workpieces, the CNC Vertical Turret Milling Machines offer strength and rigidity while providing greater versatility. The Turret Milling Machines from Palmgren are a cost-effective solution for every milling need. The milling machines produce more parts, faster and with better tolerances than standard manual machines. In addition, they are simple to set up and operate. Another key feature is the Fagor Automatic controls that offer the most cost-effective solution in chip making profitability. This combination ensures faster programming, set-up and machining. Other features include variable speed drive, a heavy-duty spline motor drive system and vent air cooling system.
